Got a load for sale.
Based in Northampton but I can post if needed.
I don't know what the majority of the parts are worth as the prices have changed so much but if there's anything you need let me know!
*Interior*
Double din head unit £60
Rear wiper motor
Oem driver's side seat in black leather £40
Glove box silver £20
Steering cowling silver
Clocks surround silver
Interior mirror £20
Sun visors £20
Climate control £35 delivered
Accelerator pedal
Rear seat air bag cover panel x 2 £10
Fuel pump cover £10
Boot hinges £20
Driver side window switch panel £20
Oem plastic foot rest £10
Cluster, bouncy rev counter
Wiper stalk
Steering column cover silver switches put in from previous owner
Door hinge
Vents
*Performance / engine parts*
Bonnet hinges £30
Looms, all apart from fuse box and engine loom
Clutch slave
Horns £10
Air con pump, fan and mounts £40
Abs pump £20
Power steering resevoir £20
Expansion tank
Bm50
Brake servo
Steering rack brackets
Bonnet release cable
T28 HKS actuator £80
S14a oem turbo elbow £30
S14a oem mani £40
Oem wimc air feed
Oem air feed
*Random*
Red Sparco harness £30
Braille battery mount
Battery tie bar £5
Red Epman battery tie bar £10
Oem tow bar
Fuel filler cap
Exhaust heat sheilds
Engine crane £100
*Exterior*
Arch liners
Scuttle tray not painted £20
Diff cover plastics £10
Rear wiper arm
Fuel pipe cover trim £10
*Handling*
S13 poly bushes
S13 adjustable bolts
S14 Drive shafts
*Interior*
Rear wiper motor
Interior mirror £20
Sun visors £20
Accelerator pedal
Fuel pump cover £10
Boot hinges £20
Wiper stalk
Door hinge
Vents
Bonnet hinges £30
Clutch slave
Horns £10
Abs pump £20
Expansion tank
Bm50
Brake servo
S14a oem mani £40
Oem wimc air feed
Oem air feed
*Random*
Battery tie bar £5
Oem tow bar
Fuel filler cap
Engine crane £100
*Exterior*
Arch liners
Rear wiper arm
*Handling*
S13 poly bushes
S14 Drive shafts
