Notty
Okay people Ive got a few questions about my 1999 s14a that I could really do with being answered and explained if you could take the time Id really appreciate it!
Okay so recently Ive had my flywheel, clutch and starter motor all replaced. As soon as I felt my clutch started to slip I bought the parts and booked it in to be replaced, all has been replaced and they are completely fine.
So when my clutch was slipping I felt that because it took alot more revs to get up to speed it was causing my turbo (stock, never been changed) to lag really quite noticeably, now the lag has progressively gotten worse and sometimes it wont spool up at all....
Now lately Ive really avoided trying to spool the turbo and avoid boost, ive only started just using the car just for commuting to work.
So the mileage is currently sat at 89,000, ive owned the car since 65,000 miles and ive replaced the oil every 5000 miles.
now ive also noticed the car has started to idle quite rough too, a weird thing is that when I sometime turn the steering wheel full lock it really struggles to stay alive (i do not drift my car).
Okay so I did the wiring harness loom tuck under the drivers wing, the wiring is still visible coming from the firewall, there is a dirt build up but no visible chafing or damage. could this be something to do why it nearly stalls when turning the wheel full lock?
Also the turbo I think maybe on its way out or could be fine, maybe other factors causing it not to preform like it would normally do?
I have a japspeed front mount intercooler on and a blitz cold air intake and thats about as modified as it gets in the engine bay.
could this be:
Boost leaks
coils
Plugs
could it be something to do with the timing chain? I have nightmares about this as I used to own a BMW and the guide snapped on that and bits fell into the sump.
If youve come this far thanks for reading and I am eager to hear your input!
cheers
Notty
could this be:
Boost leaks
coils
Plugs
cheers
Notty
