S14 - S14a PFC, ecu/ power fc Q
fubars14
Have a power fc that was mapped in my 14a (uk spec kouki) bought a missile of a S14 with similar mods and you guessed it!! i want to put the 14a power fc in to the S14 (zenki uk spec)
What wires do i need to change on the ecu plug to make my PFC work in the Zenki S14
Have any of you come across this? :dw:
Or has anyone got a good source for both S14/S14a ecu pin outs?
done reasearch but not found a detailed enough diagram to chance a pfc so thought you nuts might be able to help me out
Also will my tuned map save on the pfc or will it revert to its base map when pluged back in?
the ecu headers are different on the s14 and s14a ecu's. you will need to get a s14a loom header and wire it into the s14 loom
yes, they are. and as you are using a power fc the nats is null and void. so i suppose you could just change the loom for a s14a one
or, you should find all the pin outs from sxoc
Guy on SXOC (sammos13) has a conversion harness to allow an S14a ECU to fit into an S14 loom. Not sure what he wants for it, but you could PM him on SXOC and ask.
