s14a exhaust
owent
hi guys, i got a new turbo elbow and the downpipe from you, and it says if you buy both they will fit the s14a. but now they are fitted they ever so slightly touch the underside of the car causing vibration. is this normal?:confused:
cheerz
If it's a case of it touching a heat shield then sometimes that does happen if the shield is already slightly bent out of place or something, have a look under and see if it's just a case of just needing a shield bending out the way a little.
