s14a full system
owent
hi guys, i have bought the full japspeed system from you from turbo back, and when i came to remove the cat, the decat pipe seems to be about an inch short????:confused: is this normal, cos it will close up if i bolt it together but then the tailpipe is gonna sit underneath the bumper?
any help appreciated
are you sure you have the full system? turbo elbow, down pipe, de-cat, cat back? sounds to me like your missing the solid down pipe? at the min from the turbo do you have a flexi pipe? if you do you dont have the "FULL" system
Sounds odd, since you've replaced everything it really should all line up, can you measure the decat for me? I'll double check, it may have been boxed up incorrectly.
ill do it first thing wednesday, im away at the moment. just so i know, imagine you where looking form above, how far out should the tail pipe sit? with the cat on mine sits about 20mm out, so if i put it on it tucks underneath.
Bizarre, with the full system replaced that should be the correct length (310-315mm) but obviously not. We've got the longer 345mm versions in stock too, give me a call today and I'll arrange collection of your decat and delivery of the correct length. :thumbs:
thank you very muchly for sorting this out for me:):), the spacer is finished now and it fits fine thanks. cheers for all the help, and the stickers.
:dw: = :worthy:
