I installed my subframe bushings on the rear subchassis and now I am having lots of problems fitting the frame back on the car. It seems that the front long studs are closer together and the distance between the front and rear studs are off as well. Is there any possibility that the aluminum bushings can be widened without causing the geometry of the subframe to shift? This really has me stumped and frustrated, have been trying many different variations for the past month. The bushings fit fine by themselves but once on the frame it is no go . Any ideas will be greatly appreciated.
