Skyline help
lesleys14
hi everyone as title have skyline r32 gtst and recently a couple of times struggled to get in fourth gear
Then the other day went to get car from garage went into reverse but made a noise is this possibly clutch going have done a few drift days and had exedy stage 1 clutch and lightened flywheel fitted a couple of years ago
Or could it be diff I have a two way one fitted about 2 half years ago
Any help please
Lisa
Try to look at the clutch, probably needs replacing. Not only that but check the diff since 2 years is along time, especially when drifting the hell out of a car. And how old is the differential fluids. The clutch going means that it's slipping. Check the clutch again check back. I'll see what I can make out of this. I've had a closely related problem in my 350z, but that was because the clutch was worn and really gone. So check the clutch to see if it slipped or is abnormal, and yeah, check all oils.
