SPA Design Gauges. Multi colour dual readout in one gauge
PhilMorrison
Driftworks Owner
Staff member
We've used SPA Design Gauges in the Driftworks R32 for a while now. But supply was a bit to much of an issue to be able to reliably offer them to our customers at the time. Now they are readily available and assembled to your spec in a day or two, So we're happy to now have them available in the shop.
52mm Dual Gauges. Options for pretty much any combination of: Oil temp, Water Temp, Fuel Pressure, Boost, Voltage, EGT.
Get your SPA Dual Gauges - 52mm from Driftworks.com
80mm Tacho with options for additional readouts, so you can have Boost or MPH displayed on the tacho as well. The needle can be set to change colour at certain RPM's too! Very cool!.
Get your SPA Automotive Pro Tachometer - 80mm from Driftworks.com
