Sparco Seats In DW Frames
Parker
Will the Sparco Pro 2000 fit in your frames? Just thinking about alternative options since Phil let me sit in his at D1...
as long as the base is no wider than 420mm, IIRC the Sparco Evo 2 doesnt fit as it has a base of 460mm..
I think the Pro Does, but its easily to check on the sparco website, and the dwshop has the measurements of the frames on..
Hope this helps..
Cheers Sammy. Thought it would do as it's a narrow little bugger.
The EVOII is a bit of a wideboy seat... :D
Can you guys get Sparco gear in? I'm after a pair of the Pro 2000 by the looks of things.
EDIT: Phil will know this, do the cushions on the bottom pull out like they do on the EVO?
