SPEC Clutch Group Buy
PhilMorrison
Driftworks Owner
Staff member
Spec Stage 3 Clutch Kit:
A serious Paddle Clutch for high horsepower, drifting and drag. It's not quite as slippable as the 3+ but is still street drivable and has a light peddle feel, and most importantly handles abuse well.
SPECs description:
Features a carbon semi-metallic 6 puck sprung hub disc that has been the leading puck clutch in drivability, life and torque capacity. This unit is designed for street and race cars that require an aggressive but streetable engagement and high torque capacity. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability
Kit Includes
  • High clamp pressure plate
  • Carbon-Graphite Friction Material
  • High torque sprung hub and disc assembly
  • Bearing and tool kit
Spec Stage 3+ Clutch Kit:
We used this in our Driftworks Toyota Chaser 560bhp. It has a mega light pedal feel, and being a full faced disk it has a firm engagement, but is actually quite 'streetable'. It has a sprung centre so it's as friendly as is possible with your gearbox.
SPECs description:
The flagship stage for a high powered street or race car that requires a manageable and friendly engagement, the stage 3+ features a carbon semi-metallic full faced material that offers unparalleled life, friction co-efficient and drivability characteristics in one single package. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability.
Kit includes:
  • Carbon semi-metallic friction material
Driftworks Lightweight Flywheel:
Simply a must have item on a drift car. It completely transforms how the car responds. Particularly on a drift car. It helps with clutch kicks, adjustments behind other drivers, engine braking, and helps spool up turbo's quickly.
Made from Chromoly and machined to the highest standards.
Here is the clutch and group buy details.
Please note the Ft/lb's of torque is what they are rated to in the USA. Obviously when drifting we are giving the clutch a lot more abuse than normal, so take the figures with a pinch of salt. As a rough idea, the Stage 3 SR20 clutch is good for about 400ft/lbs in a drift car.
The group buy price is available as below as long as we get 5+kits :thumbs:
We can get absolutely anything SPEC makes. They make uprated clutches for almost any car you can think of, and they can supply some high quality twin plate clutch and flywheel kits.
So if you are looking for a clutch not listed above please ask and we'll work out a price :thumbs:.
Get your names down here people, and we'll contact you to take payment :thumbs:
The Group Buy will run until Nov 10th
intersting, what's the timeframe on this GB as i'm currently short on cash...
and are the friction pads itself replaceable or the disc itself (how much $$$) - could be interesting in the long run?
The group buy will end on the 10th of November. And we should have them within a couple of weeks from that date.
Friction plates are replaceable I believe. We've not got pricing for that at the moment, but i'm sure it'll be reasonable.
sweet, when will you need the monies by big man? 10th Nov?
Yeah get your name on a list below, like:
1: Jason: 1JZ Stage 3 and flywheel
Then we'll give you your total and you can either paypal over or give us a ring with card details :thumbs:
Hi Karel. We can supply this for an S15 no problem. The clutch price is the same, but the S15 6 speed flywheel is £250 when part of the group buy :)
ill take a spec 3 for the s14 sr20 please
1) Jason - 1JZ Stage 3 and flywheel
2) AntB - SR20 Stage 3 to suit s14
This is ending today people.
We have 5 people on the list, so you get the discount. We'll be contacting those of you that haven't paid shortly :thumbs:
Phil what prices and bhp/torque capability can you do for mx5's?, as there's a fair few on the mx5nutz forum that would propably be good for a group buy.
