I searched and didn't find anything so here is my question.
Eventually I'm going with a bigger turbine, I'm aiming for around 500whp. Right now I have a TD06-20G and around 380whp on a S14 5-speed. I'm basically at the breaking point of my transmission especially with some sticky tires on it. My question is, what is my best option to upgrade the transmission?
Options available to my knowledge;
-RB25DET transmission with the bellhousing cut off and SR bellhousing rewelded in it's place.
-VQ30 transmission with an adapter plate from Mazworx
-OS Giken gearset in the stock transmission
-Full OS Giken or HKS "crossmission" or "dogbox"
Is there anything that I'm missing or don't know about?
I'm leaning toward the RB25 transmission mainly because it is the cheapest option but would need a competent welder to make sure it is aligned and welded correctly. I've heard that the OS Giken gearset is not even as strong as the RB transmission and the OS crossmission is just way overkill for a daily driver.
Thoughts?
Thoughts?
