Sr20det BlackTop Throttle Conversion
Keep the normal throttle body or Convert to Electric
  • Use cable throttle
    Votes: 0 0.0%
  • Total voters
Lin441
Hey I own a s13 and I've converted it to sr20det Blacktop with a standalone Ecu Masters
I'm looking to convert the throttle body to Electric I've found a website that sells a kit but think it's to pricy for the throttle body https://www.ptmotorsportelectrics.c...tor-bosch-68mm-to-sr20?variant=39340080988211
Was wondering has anyone converted their and if so what throttle body they used?
I wouldn't mind buying the adapter and the throttle alone since
BOSCH 0 280 750 473 Throttle body
looks like the same one they are selling on the website with the adapter.
hey mate
yea yea you rogth is the same
but for electric you can get one from xtrail sr20vet is 70mm
and is oem electric you know i think yours is 62mm something ??
or from some german cars
i home to help you
Just buy the Bosch 0280750151
It's 60mm and the bolt pattern is the same as the stock sr20 bolt pattern (60x60mm). You just need to drill out the holes to accept the m6 (?) OEM throttle body bolts.
I'm driving this throttle body on my sr20 with a Link and it's flawless.
Mind asking what connector it has for the throttle body is it 6 pin?
I'v got the same TB on my S15 with Link, I think I paid about the same as that adapter plate linked for a brand new bosch TB from opie oils.
It's bolt on and if you use Vag throttle body bolts no need to drill either as the threads are the same, 1.8t bolts iirc, was a while ago.
The connector I believe is a bosch motorsport TB connector (also used many run of the mill standard cars) readily available, a quick google and you will find it.
