Urnes_s14_on_ig
Hey. Have a s14 with sr20 and everything was fine untill i drove it around the block once, didnt go over 2500rpm. But once i got back at had tiny backfires at idle and got the fault code egt ch3 to high, what could be wrong?
Have it set to 15, so unless it has changed itself it should be goodReally bad ignition timing?
Got no cat, 3 inch straightpipe, did change plugs and compression tested it and it was all good, and ran fine after, so maybe just bad plugs?blocked CAT?
And the car isnt tuned yet so it runs rich, so im asuming it was just the black plugsNgk bk8 something, but put bk7 in yesterday
