Urnes_s14_on_ig
Hey. Replaced my headgasket and on startup the car is running lean and struggles to get the rpms up due to missfire. Have pressure tested the hole engine and fixed all the leaks. But, if i rotate the cas away from 15° btdc i runs alot better. So is it possible that i have installed the cas incorrectly?
Also had a backfire through the intake so thats why im thinking timing
