SR20DET parts - garage clearout
S14/a PARTS PIC HEAVY - ALL MUST GO
Got a few bits to get rid of that are no longer needed in my life!
SR20DET bare block - removed from a UK S14a, the car had 110,000 miles and had one owner and plenty of
Nissan dealer service history up to 100,000miles - the engine spun a bearing so it was removed.
Everything on the car was stock apart from a H-Dev stage 1a ECU, CAT back, walbro and a disco potato
Running 1bar - there's a slight groove in the liner on cylinder number 2 please see pictures - £50 collected
S14 power steering pump - with mount bracket, looks pretty good. - £60 collected - £55 posted (quite heavy)
APEX red wheel lug nuts - with key - only got 16 of these and the key has been used - nuts brand-new - £10 collected or £15 posted
Timing chain and guides from the same engine - chain looks good, no tight spots - £20 posted
Timing chain cover - looks to be ok - cleaned it up a bit - £20 posted
Stock oil cooler assembly and filter location, bolts present - looks to be ok no damage to the seals -£25 posted
Stock thermostat with housing assembly with bolts - £25 posted
Stock flywheel - few heat spots, never been dropped, teeth look ok - no bolts - £30 collected - pm if you require postage, please include postcode so I can use interparcel to get a quote.
SR20 pulley belt kit - brand new in packaging - £20 posted
sorry for picture size, pm if you want then emailing - cheers guys
The main bearing caps belong to the engine they were originally bolted to and cannot be placed on another engine without machining!
