SR20det problems after hydrolock
Hey. My sr20det got hydrolocked due to stuck injector, changed the injectors and the car started fine. But after the car gets hot now, the idle drops to 400-500rpm and it idles really bad. Sometimes even stalls. I have gotten a fault code of a bad tps and replaced it. Now the rpm dont change after warmup. Could there be a bad temp sensor?
Its on bottom of the bit that the throttle cable joins to, should be a small allen grub screw to adjust where the throttle closes
Nor did i but somehow it was out lol, tried different tps and mucked around with the idle control valve until i realised that was my problem
