Urnes_s14_on_ig
Hey. Ive got an S14 with an sr20det thats recently hydrolocked due to bad injector.
I have replaced the injector but the car wont run right.
It idlea bad once hot and when I go to drive it it turn itself of if i give it too much gas.
Ive checked:
IACV
TPS
ECU coolant temp
Compression
Ignition
Timing
Fuel pump
The exhaust manifold is leaking due to missing a stud, so will fix that.
And there is a tiny vacum leak somewhere but it have vacum.
Will be replacing fuel pressure regulator too.
Is there anything else i could check?
Ive checked:
IACV
TPS
ECU coolant temp
Compression
Ignition
Timing
Fuel pump
