SR20DET S13 For Sale
'93 L reg UK spec 200SX ~110,000 miles
Engine
Red-top SR20DET from '93 180SX - ~75,000 miles
Mines Stage 1 ECU
Apexi filter
HDi FMIC & pipework
Buddy Club Spec II exhaust
Circuit Sports combined elbow and downpipe
Megan Racing decat
HKS adjustable actuator @ 1 bar
Nismo engine and gearbox mounts
Suspension
Apex coilovers - 8kg/mm front, 8kg/mm rear (also comes with 6kg/mm rear springs)
Alloy subframe bushes
Alloy steering bush
Poly steering rack bushes
Adjustable G-force pillow-ball tension rods
R33 GTSt front lower arms and tie-rods/ends
Spacers on tie-rods and ground down lock-stops for more steering lock
Powerflex rear arm bushes
5-stud conversion
R33 GTSt brakes all round with braided hoses front & rear
ABS removed
Electric line-lock in front brake line (not wired up)
Welded diff - oil cooler, pump & lines removed
Interior
Candy stripped interior, still has tar soundproofing
Sparco Evo Bucket seats
Drivers side - Bride subframe
Passenger side - home-made subframe
Sparco 4-point harnesses
Sparco 330mm wheel
OMP Boss
Sparco 30mm steering spacer
B&N style quick shift
Nismo "Darth Vader's Cock" black resin gearknob
Sparco Aluminium pedal extensions (not fitted)
2 Additional steering wheel buttons (for line-lock, not fitted)
Apexi Turbo Timer
Drift button fitted to handbrake
Exterior
AG2 Red
17" Advan SAR3 wheels - 8" front (215/45), 9" rear (225/45)
Linglong L688 front tyres, Goodride Neza200 rear tyres, all with plenty of tread (rears only 1 month old)
L2K Developments URAS Type 4 replica bodykit
Brilliant beginner track/drift car, not far off drift competition spec - would need a cage, extinguisher and electrical cut-off. Car makes me look like I can drift so should be awesome in the right hands ;)
MOT & Tax due November 2007
£4000
Car is in need of a replacement front bumper after the original one was removed by a flooded section of road recently - this will be supplied, fitted & sprayed as part of the purchase price.
Car is definitely not mint but the shell is one of the best S13 shells I've personally seen and worked on, and most of the Telford people (kiruji, Russ200, Doz) know the car and can correct anything I may have missed off or got wrong :o
Viewing recommended, test drive not a problem as long as you bring the cash with you and proof of insurance :)
tetsujin said:
well, it looks like alot of s13 for 4k
good luck with the sale mate.
apart for a redtop SR20 in it ??? its a 180sx money because... its basicly a 180sx..
you want some 180sx rear windows :) make it proper :)
redtop enignes are not cheap. this is a good price.
I can vouch for this car, it's aceness. Seats are a bit tight for my fat arse, but as long as your only 2XL or smaller you should be OK :D
Oh and you might want to edit your post so it reads '93 rather than '73 :wack: ;)
'73 so it's tax exempt innit :wack: Editing now... :D
Thanks for the positive comments guys :)
GORGEOUS!!!
I really want it....and I haven't said that about any car since I got my current s13.
Thing is, getting mine up to your spec would easily cost in EXCESS of 4k, so this would make a good purchase. Hmmmm.
EDIT: More pictures please.
you need to learn to read.
I SAID
ITS ALOT OF S13 FOR THE MONEY.
IE
ITS A FUCKING BARGIAN COMPARED TO MOST OTHER S13's AS ITS CHEAPER THAN MOST 180SX!!!!
:mad:
Shame your selling dude :(
I too have seen this car and it also has the worlds quietest exhaust bung (btw Matt you forgot to mention that ;))
adrianstokes said:
Lovely car, well worth the money :nod:
That's not what you said at JAE dude :wack: :D
Good point, the Buddy Club exhaust also comes with a "removable silencer" which quietens it down an insane amount, also makes it scream like a banshee on boost :D
