Steel Bubble Arched Mk1 Escort Project with Camed Zetec T/b's & Cage
escortalex
For Sale is a Mk1 Escort Shell with Steel Bubble Arches
Car has a weld in cage, been turreted, got a panhard rod, weld on strut brace and has had the fuel cap smoothed over.
As can be seen, the car is unfinished but needs very little doing, needs a firewall welding in and then painting.
The package includes
* as new cossie rear discs and calipers (all fitted to the rear axle)
* Just refurbed (as new)Coil over Bilsteins with 190lb Springs and as new Top Mounts
* New pair of Bremsport 4 pot alloy calipers and pads (was going to use 260mm BMW discs)
* Quick Rack
* Anti Dive kit
* Bonnet, Boot and Doors all in good condition
* Set of Glass
* Front Grille
* Wiring harness
* Clocks (2 and 6 clock)
* Box of parts including hinges, handles, lights etc
* 4 off 7x13 Superlites with 205/60/13's as new
* 4 off 8x13 Weller Steels with tyres
* 5.5 Gallon Foam Filled Fuel Tank with filler (specially built for an Escort)
* World Cup Cross Member
Also included is a 2 litre zetec engine:
* Freshly rebuilt 2 litre zetec (built at Ford main dealer)
* New NGK R Lazer Platinum plugs
* GSXR1300 throttlebodies on a Weber inlet manifold (all ported to match)
* New pair of fast road/race cams (still boxed)
* Set of Piper anti pump followers
* Retroford Water rail
* Retroford Engine mounts
* Retroford flywheel and clutch
* Retroford RWD sump
* ARP Bolts used
Car is located near High Wycombe in Bucks
PRICE REDUCED NOW £5500 ono
Alex
07879 810935 or PM me
