super low base mount subframes?
narcotic
Active Member
right i need a REALLY low base mount seat from for my R32 cos my seat is massive and also very comfy :D but too wide to adapt for the DW side mount subframes.
Any ideas?
We have a drivers side super low Bride base mount for S13/S14 in stock. It's never going to be as low as a side mount frame. and to fit the R32 one of the mounting holes needs changing, but to clear it, I'd do it at £95. Any good to you? :)
Easy fix. :thumbs:
Just modded a R32 sidemount to fit a S13, you just need a bit of plate to adjust the mount point and in the case of an R32, make it shorter.
cool but the fact that it is an s body rail and having to modify it and also not knowing how low it is will be a real pain.
think i will get mr. smith to get the welder out
thanks anyways :thumbs:
The mod is really easy, and the basemount frame will be about the same height as standard. For the mod, you literally need a piece of rougly 3/4 inch long flat metal plate, drill two holes though it at either end, bolt one end through the original hole on the subframe and then you can but the original bolt into the floor in the hole at the other end of the plate. You're basically just bringing the mounting hole back about 3 inches. 10 Min job.
