N NinjaD JDM Wench Sep 14, 2009 #1 I am wanting to buy all new rear arms for my 13 but I am going to be doing a s14 conversion soon, does this have any effect at all on which arms i need to buy?
superclarkey DORITECH MOTORSPORT Sep 14, 2009 #2 s14 subframe is 10mm wider then the s13 frame.. If you push the arms out too much your driveshafts will break. The S13 and s14 arms top arms are totally different, if i was you i would buy s14 gear and get the frame on asap
N NinjaD JDM Wench Sep 14, 2009 #3 so put the 14 subframe on the 13? are all the mounting points the same?
superclarkey DORITECH MOTORSPORT Sep 14, 2009 #4 i thought that is what you meant by s14 conversion. s14 frame is 11mm wider i belive
superclarkey DORITECH MOTORSPORT Sep 15, 2009 #7 Ah right, no difference what so ever mate.. just order S13 gear
