Captain Muppet
Pro-tard
Hello,
First post woohoo. I'm preparing an S12 Driftshed and I have a question about suspension travel. I'm going to get some springs made up and I'd like to know how much suspension travel you guys are using.
The cars I've seen jacked up at competitions seem to have about an inch of sag/extension and not much more compression travel - I'm assuming that to keep suspension geometry changes to a minimum while throwing the car around the suspension travel is small and the spring rates are huge. You need enough suspension travel to get away with clipping a kerb without bouncing the other tyres off the ground, but that's about it I suppose.
I'm on a tight budget (hence the S12) and I can't afford anything much more than springs, check straps and maybe something along the lines of elastomeric damping as a bodge. I'll have to compromise between dry and wet settings, but that's having no cash for you.
I'm an engineer so I'm hoping for a target for wheel control from some of you guys before measuring the stock spring rates/lengths and working out how much I need to change them.
I'll post the results up here, if divorce/house selling/job hunting don't get in the way and kill the whole idea stone dead. :dermal:
Cheers for any help, even before and after spring rates on other cars will be useful,
Muppet.
Muppet.
