Thermostatic Oil cooler Sandwich plate
Are there any gauge take off's on this one? I need an oilcoolerkit with two gauge take off's. I have looked at this sandwitchplate, your braided oil lines and your mocal 19 row oil cooler. I use the car for hard street use and drift. Is that oilcoolerkit the choice for me?
Regards Jesper
Hi Jesper,
On the thermostatic plate there aren't any takeoffs I'm afraid. You've got two options really, depending on whether you're worried about having a thermostat or not.
Option one, use the thermostatic plate, lines, and cooler then combine it with a gauge sensor sandwich plate ( http://www.driftworks.com/catalog/products/sandwich-plate-with-gauge-sensor-attachment.html ), this will work perfectly but obviously means stacking two sandwich plates. It's not ideal, but it works.
Option two (this is what I'd do, and have done on the chaser) is use one of our oil filter relocation cooler kits. It's not thermostatic, but it has the gauge sensor takeoffs on the filter relocation plate. You can combine it with an inline thermostat too if you want, which would make it the ultimate all round kit. Only issue is the relocation kits are out of stock at the moment, we'll have an update on when we'll have more tomorrow, shouldn't be more than a couple of weeks. :)
