Thingies for end of pull cables
Jord
drifted.com
Can you guys get the little metal screw thingies for the end of the pull cables? The bit which stops the cable just coming through the thing its attached to. I've lost 2 and need to replace them. :confused:
you can use the screw thingies that come in electrical wire connector boxes. If you cut the plastic off you will find the internals are identical to the thing that comes with the extinguisher etc.
These ones:
See what I mean? ;)
