L-plates:)
Items still for sale:
-Toyota JZZ30 Soarer/ JZA80 Supra Cusco Coilovers,Could do with a clean, but no leaks etc -- Front two only, £150 ono
Cusco Coilovers Soarer JZZ30 Supra JZA80 Aristo JZS147 | eBay UK
- Soarer 1JZ/JZZ30/IS200 Clutch master/slave cylinder 1JZ/IS200 - £39 + £6p&p ono
-Toyota Soarer JZZ30 standard Diff 1jz etc. Atandard diff inc casing, i'm sure if could be welded up if you want. Came off a car with 45k on the clock and worked fine, no leaks etc - open to offers, collect from Bristol could poss post but would prefer collection
Toyota Soarer 1JZ JZZ30 differential diff | eBay UK
Lexus Soarer 1JZ/JZZ30/IS200 Clutch master/slave cylinder swap
For sale clutch master cylinder for the 1JZ/IS200
I will take £39 + £6p&p
Toyota JZZ30 Soarer Standard shocks+springs piezo dampers fits JZA80 Supra
For sale
Toyota JZZ30 Soarer Standard shocks+springs piezo dampers fits JZA80 Supra.
These cam off a car with 60k on the clock, taken off due to coilover upgrade.
All working well when taken off with no leaks or noises.
These are the Piezo controlled damper ones that stiffen up the dampers under acceleration (rear) breaking (fronts) and cornering .
You will need the rest of the electronics in the car to simply plug and play. Or if you want rest of hte Piezo electronics from my car (and know how to take it out!) you are welcome to it :)
Looking for £50 for fronts, £50 rears or £90 for the lot + postage of £9.99 per pair. SOLD
Struts are SOLD SOLD SOLD SOLD
Thanks dude,
tempted, but unsure how much headache it will be to find rear coilovers separately (not fussed about brand matching tbh).
Will have a think about it
Thanks dude,
If it helps at all I have ONE rear Cusco coilover of the same style (DHL kindly lost one in transit, hence me selling these!)
I have a standard diff inc casing from the JZZ30 soarer, i'm sure if could be welded up if you want. I upgraded to a 2 way so not needed anymore
Its not an LSD
