Twin Axle 2ton Braked Alko Trailer £800
cptsideways
Active Member
My twin axle 2 ton Alko trailer is up for sale, its been 100% reliable all year, tows extremely well. It's big enough to get my Soarer on & mine is about the biggest car in EDC so everything else drifty will fit!!
It's a proper ALKO 2 Ton chassis, 1500kg payload, each corner has its own shock unit so it does'nt bump, bounce & shunt around like most trailers do, it glides along!! Has twin wheel braking & it all works fine, has lights that all work & recently re-done plug etc. Comes with long ramps etc. Bonus it has a 12v electric winch & decent new battery (stored beneath) with a remote switch so you can drag your dead up on the trailer when at the end of the day. Tyres are fairly new too. The upper section has been custom made it works very well, its not new but does the job extremely well. Has a brand new heavy duty jockey wheel & a new emergency brake cable.
I've towed this with my Volvo V70 2.4 all year without bother, though I did remove the weight load plates from the axles to make it legal (ish) for the combo, weight plates I still have.
Rear lights are proper Britax rubber mounted, needs two lenses as two are cracked but I might be able to sort them out beforehand (£5 each) Has side marker lights, plastic mudguards etc etc. Alltogether a decent workmanlike trailer.
£800 & I can possibly deliver it too for some beer tokens, Soarer is not included :smash:
Bed width is 6ft, length is 13ft but theres more clear room at the front for overhang so really 14ft at least. See the pics how my car overhangs the bed area.
Declan ps phone number is 07970 642129
