Vauxhall redtop c20xe complete rwd conversion with ford type9 gearbox
mrdeeds
Hey all given up on my sierra project so now selling the running gear.
to start with its a vauxhall redtop c20xe 2.0 later coilpack type it has had a new head gasket and rings fitted bearings have been checked and all in good working order its been fitted with a winged rear sump from a manta to go into a ford sierra, cg motorsport organic clutch,
comes with a brand new quick release 4 bolt bellhousing fitted to a ford type 9 5 speed gearbox which comes with the propshaft yoke, brand new rs2000 clutch fork, release bearing and a new clutch cable
Also included is a walton fabrication stainless manifold which cost close to £1000 on its own.
Complete wiring loom with ecu and afms wiring is all labled to be easilly hooked up only requires a main live and ignition switched live to run. The rest of the wiring is labeled for tacho temp gauge oil pressure light etc.
For a quick sale i am after rock bottom £1500
