Perriss21
Active Member
Vestax Vci-100 usb midi controller 1.2 Version
VESTAX VCI 100 - USB DJ CONTROLLER WITH FREE USB SOUNDCARD- COMPLETE PACKAGE
Brand New With Traktor LE software (Ready to use out of the box)
Used once to test it was working, i bought this with the intention of using it, however i now need the funds
FULL UK WARRANTY !!!
The VCI-100 is a highly professional MIDI controller that has two jog wheels built with sensor and control technology straight from our turntables. One of the many additional features found on the VCI-100 is a curve generator that controls the crossfader curve giving the DJ true professional mixer features on this MIDI controller, even if the software being used doesn't allow for curve control. The VCI-100 is built with the highest quality mechanical parts and state of the art PCB technology guaranteeing accurate and stable operation
TRAKTOR 3 is a versatile and comprehensive digital DJing solution designed to meet the most professional of standards. The third generation of this award-winning software offers breath-taking sound quality coupled with an unprecedented array of new features – sure to get any party rocking. Discover the potential of TRAKTOR 3 and blend a new dimension of creativity into your mix.
Turntables of Tomorrow
TRAKTOR 3 has four fully-featured playback decks: Drop in additional loops and samples, or mix four tracks at once. The integrated 4-channel club mixer is highly flexible, allowing effects to be inserted on each channel individually. External turntables, CD-players and hardware effects can be patched seamlessly into the setup - the possibilities of this virtual DJ platform are endless.
New mixer and advanced effects
The prestigious Xone:92™ club mixer has been perfectly emulated with the support of Allen & Heath. Its excellent 4-band EQ gives incredible depth to your mix. The cross-fader assignable filters offer unique and innovative frequency-based mixing possibilities, bringing a completely new feel to your sets. Five professional tempo-synched effects and four high-end EQ's all give your sound a distinctive flavor.
Integrated Beatport Access
TRAKTOR 3 also boasts direct integrated access to the Beatport Online Music Store, allowing you to browse their extensive catalogue, pre-listen and buy hot new tracks and download them directly into your library - and all this is possible from within the TRAKTOR 3 browser.
Perfect Setup
The user interface works on a completely flexible and dynamic principle. Toggle individual control groups on and off, arrange secondary functions and displays for an optimum use of space. The new Messages Window automatically displays short explanations for the active function. Whatever the situation, TRAKTOR 3 always lets you know exactly what is happening, so you can concentrate on the mix.
(All you need to do to get the controller working & all functions mapped with Traktor 3.2 is to load the tks file from the Traktor LE version. i.e install Traktor Le then install Traktor 3.2)
or just install Traktor 3 then download the tks file from here http://www.vestax.com/v/products/players/vci100_b.html
£345 normally.......i'm after £300
- FEATURES
- 90 parameters of various software are assignable to the VCI-100's control section via USB transmitted MIDI signals.
- The JOG wheel is constructed with a high-resolution pulse sensor; touch sensor and acrylic platter mechanism. With this combination, operations such as pitch bending, scanning and scratching can be performed with speed and accuracy.
- Every crossfader motion of the VCI-100 is digitally converted and sent to the software. Curve settings are generated with the built-in CPU, which allows you to adjust the crossfader curve to your preference whether or not the software you use has curve control.
- The DATA SEND LED and JOG wheel SENSOR LED provides clear visual of the current status to assist in an authentic play mode in real time.
- Operates both with USB bus-power and an exclusive power adaptor. (For best performance and stable operation, please use the power adaptor if the computer's power capacity is low or if using a USB hub)
- There are no issues if you don't have software to operate. TRAKTOR LE (Native Instrument Inc.) is bundled to the VCI-100 with exclusive control assignment files.
- The VCI-100 provides simple plug & play working with Apple and Windows operating system computers.
- Compatible with all software that allows MIDI control assignment. Samples of MIDI control assignment files for each software will be available at www.vestax.com.
- The metal body is almost the same size as a standard Laptop, thin but highly durable, compact and convenient for transportation.
- DIMENSIONS: 360(W) x 35(H) x 252(D) mm (Excluding knob height)
- Loop/Sampler section
Lighting Square Push Sw : 3pcs
Round small Push SW + LED : 4 set - Cursor section
Lighting Square Push SW : 5pcs - Channel section (per channel)
Rotary Volume : 5pcs
Small rotary volume : 1pce
2 color Lighting Square Push SW : 1pce
60mm High quality fader : 1pce - Effect and/or Universal section
Lighting Square Push SW + Rotary Volume - Master section
Small rotary volume : 3pcs - Pitch/Tempo/Jog section (per channel)
45mm Fader volume : 1pce
Lighting Square Push SW : 3pcs - Jog Wheel section (per channel)
Touch sense SW : 1pce
Touch sensitivity LED : 1pce
High resolution pulse generator dial: 1pce - Cross fader
45mm stroke variable curve generate fader : 1pce - Transport section (per channel)
2 color Lighting Square Push SW : 4pcs - Rear panel section
Touch sensitivity level volume : 2pcs
C.F.curve control volume : 1pce
Power SW (Adaptor/OFF/Buss power) 1pce
- System Requirement
- a) Operating System
- Windows
Requires Windows XP Service Pack 2. Does not support Windows 2000/98/Me
NOTEF DO NOT connect to a Windows2000 Professional PC. The display will turn blue and the computer will freeze. - Macintosh
Supports Mac OS X 10.4.7. Does not support previous system versions.
Multi client environments that operate the VCI-100 with multiple software, is not supported.
- Windows
- b)Hardware
- Windows
CPU Pentium III 500 MHz (Advanced CPU required for
laptops)
Memory: 256MB RAM
USB 2.0 Interface
These minimum system requirements are for the VCI-100
hardware. If the software's system requirements are
higher than the VCI-100, please prepare an advanced
operating system qualified. - Macintosh
CPUFMacintosh G3@600 /
G4 1.5 GHz or Dual Core 1.6 GHz@667MHziA faster CPU is required for laptopsj
MemoryF256MRAM
USB 2.0 Interface
- Windows
- 2 Beat & Tempo Synchronizable Decks
- Instant Loop Function
- 4 amazing Master FX
- Integrated Beatport Store Access
- Ultra-Fast Database Browsing and iTunes-Import
- System Requirements
__Windows XP (SP2), Pentium III or Athlon 1 GHz, 512 MB RAM
__Mac OS 10.4, G4 1.5 GHz or Dual Core 1.6 GHz, 512 MB RAM
Perfect Setup
