jonny mac
1jzS14
Item:- w58 manual gearbox + clutches
Condition/Mileage:- unknown, all parts were bought second hand from various people trusting their word (I'm not to be held responsible if these items have issues)
Price:- £750 (following on from the last w58 I seen sell)
Postage: courier available at buyers organisation/cost,
Collection From: happy to meet buyers in/around Aberdeen scotland
gearbox is a w58 5 speed manual, it came from a jdm import soarer that had been converted to manual, it has a remote shifter linkage and a jz bel housing
the gearbox I was told is good condition but I'd never personally drove with it so I can't vouch for it/be held responsible for any whines or crunches etc, it engages all gears fine however on the floor with the shifter when being tried out
there are two clutches, one 6 puck performance clutch, also an exedy single plate clutch disc and pressure plate (has a small crack on an edge of the clutch disc from postage but cover is good) pressure plate bolts too
flywheel inc crank bolts
will come with a release bearing, fork, slave cylinder, spigot bush for crankshaft
front section of propshaft will also be supplied, it fits into the back of the box and you'll need to use your existing supra middle bearing onto it as the bearing on it was retained for the soarer's body shell when removing box from car
w58 gearbox mount rubber bush will also be left on the gearbox
box also has electronic speed sensor and reverse switch on it
Pictures:
resealed cover
Pictures:
resealed cover
