Wanted WANTED-lowered suspension for AE86
John F
Wanted a drift spec set up for my 86, something really low and decent.
Can't seem to find anything apart from 35mm springs!
If anyone has anything of intrest, let me know. Cash waiting... :wave:
John
Got some TRD rear springs, they need cutting but are quite stiff. £50 plus P+P?
that sounds cool. How about the fronts?
Is it worth making the front stiffer than the back for better drifting?? :thumbs:
A nicely balanced setup is about 3:2 Front-to-rear ratio. You can run the same rates front and rear but in a lightened car this isn't needed.
I can recommend 4kg/3.2kg for road use or about 6kg/4.5kg for an ocassional road/lotsa track car.
Go coilover conversion on the front. I can sell you a brand new pair of struts for conversion if you want. It's an easy cut and weld job and will transform the ride and handling of your car.
Front springs i cant help with at the moment, i might be able to get you some soon however. These would only be lowered TRD Springs however, and possibly dampers but it depends what we do with this particular car and when.
As Will says, coilovers up front are best, but i prefere stiffer spring rates than he does (particularly for the rear). If you lower the rear you'll need a new adjustable pan-hard rod, and if you lower the front i'd recomend you get some RCA's aswell.
I think i can get you shocks, RCA's and the panhard rod also. PM me for details :)
Paz
