Wheel nuts for super advans needed.
E-Bay is your friend.... Do a search for Hex nuts.. was a while ago i bought mine, just make sure they have the right thread size....
You DON'T need internal drive nuts for Super Advans, I'm using a set of Kyokugen wheel nuts from Apex (~£35), the DW ones on the link look pretty similar dimension-wise though so they might also work :)
Be careful if you are buying internal drive wheel nuts. I can say form experience anything made out of Aluminium should be avoided!!!
I finally found a set of steel internal drive wheel nuts. They were made by do-luck (I don't know if DW deals in this particular brand though)
are they lockers as well?
as I've got internal drive jobs on with my advans at the mo. which are too long so the centre caps and nuts won't fit properly.
Kindof - they're 7 sided so a normal socket won't fit on, you have to use the socket/key thing that comes with them. They're not unique though so a socket from one set will undo anyone's wheel nuts - combined with the anti-theft centre cap they're secure enough for me to be happy though :)
Oh yeah, they're also steel so shouldn't have problems like you get with alloy ones rounding off and stuff.
I've got normal nuts on my Advans too. They're 17mm across flats, and a normal socket fits ok.
