Which Chassis to Build
MGMTF
Hello, I am new to the forum and also to the sport of drifting. Basically I have a heads/cam LS1 sitting on a shelf that I haven't been able to decide what to do with and I have been wanting to try my hand a drifting for a few years now so I figured I might as well use it in a drift car. Knowing the LS well (have a few other LS powered/swapped cars) and being used to driving a V8 car has really lead me to wanting to swap whatever I get instead of trying to use the stock drivetrain. Also opens me up to rollers or cars with bad engines.
However I am having trouble deciding what chassis to start with. I originally had the thought of using a LS1 4th gen Camaro/Firebird or a C5 Corvette since I own them already and am familiar with them (but would rather not drift with the ones I currently have, would buy a second one). However neither of these options make use of the existing engine I have nor give me a chance to mess with a different platform. While the 4th gen would be cheap, there isn't much offered for them in the way of drift parts. The C5 has a growing drift aftermarket but the entry price, even for a salvage title car, isn't as cheap as many other options.
So that leads me to my main question, which car to buy and swap. Ideally it is something with a good aftermarket for drift specific parts (angle kits, dual calipers, etc.) and is relatively cheap to purchase upfront. The list I made so far is a Nissan 350Z, Nissan 300ZX (Z31 or 32), BMW E36, and BMW E46 (both 2 door). From looking in the local classifieds it seems E36s are easily the cheapest option out there but from what I have seen everyone raves about how well a 350Z drifts especially for a beginner so I am torn. The 350Zs in my area are also generally somewhat expensive but the benefit with them is the stock trans is easily capable of handling the power from the LS1. 300ZXs seem to have a more limited selection of parts especially Z31s. While obviously parts can be fabricated for any chassis I am trying to start with something that has "bolt-on" parts available so that as I progress with driving I can also upgrade the car relatively easily along the way.
Any input on the cars I listed out or suggestions for other chassis would be appreciated. I am also trying to stay away from S-chassis cars as the ones around here that aren't garbage are very expensive.
As an aside, I think the closest drift events to me in Northern Maryland would be at Englishtown raceway with Club Loose. If anyone knows of any closer I would love to hear about them as well. Thanks!
350z is heavy. E36 would be the best choice but don't swap it straight away go drive it stock then swap the v8 into it if you must.
350z is my choice. Weight isn't a problem, especially with a warmed LS going in. Huge aftermarket support for the chassis in the US and a proven combination too tbh
Should be easy enough to pick one up with a popped motor seeing as though they aren't the most durable / like to make oil disappear. Factor in the price of a Collins CD-transmission swap kit as well and maybe a Holly Terminator if you don't have an engine loom - they seem like an awesome piece of kit from what i've seen.
Have a look at Taylor Ray on YouTube. He's in FL and runs one of those Collins kit's in his LS swapped Miata and has a bunch of videos on setting up his 350z practice car. Combine the two and you're onto a winner.
Also on YT, DriftHappyTV (Marco - one of Taylor's mates) documents a guy called Matt The Ginge who runs an LS 350z with a Collins swap kit. That car is a little more OTT as it's a ProAm car, but has a lot of worthwhile info for you in it.
Happen to know the weight difference between the two? I may try out the car stock, depending on what condition I get one in.
I have actually seen videos from Taylor Ray and seen those other guys floating around in them. He and Adam LZ are really why I want to try drifting, seems like a lot of fun. I will have to watch some more of his more recent videos in depth though as I didn't realize he has a CD in his Miata. Thanks!
