Jord drifted.com Feb 24, 2005 #1 Is the S14 diff interchangable with any other model diffs? I'm after an aftermarket 2 way and it would help if I had a broad band of models to search for!
Mitch In moderation Feb 24, 2005 #2 As long as you get the output shafts, all the 200's and R32 ones fit into the casing.
Genjuro keyboard drifter Feb 24, 2005 #3 How come you can't use the standard shafts, or am i being thick?
Mitch In moderation Feb 24, 2005 #4 There are different output shaft lengths and diameters. it just saves hassle if you have the matching bits.
E emuman240 New Member Feb 25, 2005 #5 which diffs are best? Which types of differentials are best for drifting? or does it really matter? whether they be posi-trak, limited slip, or any others. Matt
Matt_S SELLIN' UP!!! Feb 25, 2005 #6 emuman240 said: Which types of differentials are best for drifting? or does it really matter? whether they be posi-trak, limited slip, or any others. Matt Click to expand... Did someone say 'Search Police'??? It varies on your own preference. The std LSD needs to come out though
E emuman240 New Member Feb 26, 2005 #7 Well what should I replace the std LSD with? or is that also preference related?
