Which plugs for S13
Adam
Active Member
Which grade plugs are recommened for a CA running 15psi
Oh yeah and was it 15 BTC on the timing side?
It's been a while since i messed with s13's :wack:
Adam said:
sorry i meant which NGK plugs as my work are NGK stockists ;)
You can still use the Website to look up the part number you need and use the xref button :nod:
NGK BPR5E Standard Preset £2.7
Alternative part details:
Denso IW16. Iridium centre electrode Preset £9.9
NGK BPR5EIX Iridium centre electrode Preset £6.84
NGK BPR5EV Gold palladium centre Preset £5.94
You'd want a cooler plug, most use a 7 (BPR7E), I'm using BKR8EIX on my S14
Standard plugs are 6's not 5's.
For 15psi use either....
BCPR7ES-11 but regap them to 0.9mm.
PFR7B.
BCPR7EIX.
I'm using Denso IQ24's in my S12 at 14psi (S13 engine). No problems to report and they are still looking good as new :thumbs:
