Z31
Should be fine like any other RWD car.
What are the prices like now, they've got a pretty cool retro look IMO.
It looks awesome 3.0 v6 turbo few custom parts I'd be surprised if he ain't a member on here
He wants to swap (should of said swap instead) for my r33 so cudnt tell ya what it's going for wish someone cold tell me what there worth tbh
That black SWB z31 that was on here before looks pretty special but I'm not sure how or if that was skidded. Certainly the LWB z31 isn't worth bothering with as a serious drift car in my opinion unless your looking to spend a whole load of cash on modifying the crap out of it. Stock the z31 is overweight, underpowered and has a tendency to rot like a bitch.
I've had three over the years, the engine blew on the one (grey NA) the other rotted away beyond repair (again it was NA) and the other just didn't work (turbo version). After stripping the shite out of it I skidded the grey NA for an hour or so over a few days before the engine blew, but to be honest what was achieved wasn't really worthy of the term 'skidded' in part due to my own personal skills but largely due to the fact that it just had no grunt.
With a better driver, some serious weight loss and maybe an SR conversion (or something with a bit more power) I could see potential but there are far better alternatives out there for the amount of money it would cost to achieve
The old red one that I had literally just rotted away
I'd personally like to see somebody build and skid a SWB z31 but as I said I believe that the investment needed would put most people off.
Looks a mess, ie a drift car.
Should drift fine, engines are awesome, used in many many successful world class race cars.
Clearly I had three duff engines then as personally I thought they were wank (though to be fair they were all around the 90-100k miles mark) I'd be very surprised if the VG30ET was/is still running anywhere near the 240bhp that Wikipedia is currently quoting and it certainly wasn't anything like a GTP race engine
by the looks of it the VG30ET used for the GTP race car was very loosely based on the production engine
The GTP ZX-Turbo was named due to its shared engine with the production Nissan 300ZX, the turbocharged VG30ET V6. Although the engine block was similar, the GTP ZX-Turbo's engine was extensively modified to cope with the stress of racing.
I'm sure it could be improved drastically and I do recall there being a few decent US z31 builds, however UK examples are by and large stock, relatively underpowered and riddled with tin worm
The IMSA engines were actually no more modified from standard than any highly modified road engine, they are strong as FUCK.
Stock rods good for 700bhp.
Stock crank good for 1000bhp and 9000rpm.
Ported 12V heads capable of 1000bhp.
And so on.
Engine
3 Litre single turbo VG30ET engine , Its the earlier model with the T3 turbo and not the T25.la
30a Gearbox (strongest one)la
Pipercross air filterla
NGK iridium spark plugsla
Blitz Intercooler
apxi bov
laAVCR Boost controllerla
S13 50mm alloy rad custm pipeing
Twin Electronic fans
laCompetion clutch stage 5 rigid clutch (fitted less than 600 miles ago)
Walbro 255 fuel pump
Rx7 injectors.
la3" straight through exhaust TO straight pipe.
Custom intercooler pipeing
Washer relocated to the in side of the car.
New leads &ladizzy
oil is changedlaevery few monthsla
Inlet of the 87 turbo for better flow.
Suspension and Steering
Rear subframe polybushesla
Tein rear coilovers with 550lb rally springs (s14a)la
Custom rear strut tops for coiloversla
Fronts custom made coilovers buy gaz new topmounts
Driftwork lock spacer (200sx one)
Hydro handbrake (wilwood master cylinder)la
Welded diffla
25mm Hubcentric spacers on the rear 23mm on the front
laFront strutbrace
Upgraded anti roll bars Polly bushes.
Rear subframe Polly bushed.
]Interiorla
la
Sparco Corsa seat x 1
Driftworks harness x 1la
Avcr Boost controllerla
Stripped out interiorla
Rear harness barla
Custom made shifterla
snap off steering wheel
laElectric fan over ride and fuel cut off switch
Brakes
Rear has just had new pads , nothing special but lock up nicely on the handbrakela
2 Piece 3G 200sx front discs and conversion kit (4 pot 200sx brake)
Ferodo ds2500 brake pads (half worn)
Spare yellow stuff brake pads (half worn)
Braided extended front lines That as much as I can remember although I'm sure there some bits I've missedla
Bad bits , The car itself is from the 80's and is certainly not perfect , Specially as it is used as a drift car every other week ,la
The paint work is ok , Has some bad parts , Both lower rear wheel arches have been welded and fillered , But was only done quickly , At the end of the day its made to be driven not looked at. They has been some welding on the bottom of the car , Its from the 80's and made by nissan it was never gonna be perfect. The front bumper and splitter have paint missing in places. ec
What you guys think
The list looks ok mate but I'd be inclined to go and take a proper look at it in person in daylight and be brutally honest with yourself when you're there. Look beyond the paint and check for rot underneath the rear bumper, around the rear light area in general and inside the wheel arches.
Assuming that any problematic rust areas have been sorted/welded then I'd personally say it's worth between £1500-£1800 and that's based on the fact that it has an AVCR fitted (assuming it's the newer type and that it's working) and that it's fitted with TEIN coil overs (again assuming they aren't shot to shit).
Of course if z31 prices have rocketed in the last few years then disregard my last but I don't see it being worth anything like £2500
That's just my opinion of course
Ohh sh#t, I rememeber seeing this for sale a while back, suuuuuper cool man, how many do you see rocking it these days? Z31's rock sooooo hard! I'd go for it mate, you'll be smiling whenever you whip it, and you'll be smiling harder when it becomes (not if it becomes) one of a hand full left!
True it's just I don't wanna risk getting it then when time comes to sell if it won't sell il be left with it that's the only thing really
In my opinion, a decent drift car is just a car that can be bought, drifted and repaired for not too much money. A lot of people buy S14s / 13s or Skylines without really thinking about it, just because they've seen them drift on the internet. I've had an S14, and while it did drift pretty well, and there is a good used parts base, etc., they are much more expensive and prone to breaking than things like BMW E36s, that just go on forever taking abuse. Basically, if the car is rear wheel drive, and you can buy it and drift it within your means, do it. That's only if drifting for the sake of drifting alone is your priority. But I think it's good if you can also drive your car on the street and generally live with it and love it, so in that case it's maybe better to buy a car that you also enjoy the looks of as well. It's a all about fun at the end of the day. :)
