James D
Hi guys, I've been doing a lot of research into the Z33 gearbox conversion as i feel it's probably the only way i can go with my S13. The engine i have has blown 5 SR gearboxes and 2 RB gearboxes already so i don't fancy chancing another SR/CA/RB box! It's a 500Bhp straightcam SR20 which will be running a GTX3076r and used for drifting/gymkhana/autosolos/track racing etc so will be getting abused to within an inch of its life but i'll want it to not be shitting a gearbox every event.
First problem i face is obviously i don't want to take the car to mapping with the SR box i have, for it to only strip 5th gear, then 4th, 3rd, 2nd and first in no particular order so i figured sell the SR box and do it right to start off with.
From what i already know through researching (Please correct me if i am wrong with any of this):
- Gearbox is a Z33 CD009 from an 03-09 350Z however to guarantee it is the right box, 05-09 should be a safe bet because of redesigning etc. Earlier gearboxes are prone to breaking due to a poor synchro design however these boxes are triple synchro and are known to be running stock in 9 second 1/4 mile cars.
- When used with a 4:1 R33 manual diff:
~1st 36Mph
~2nd 59Mph
~3rd 84Mph
~4th 108Mph
~5th 137Mph
~6th 172Mph
- Can be used with SR20 clutch and flywheel
- SR20 starter motor fits as usual
- S13 trans tunnel needs widening however S14/S15 will fit with a bit of hammering near the bulkhead
Now, the adaptor kits that i can find consist of two options.
1. Adaptor plate (Maverick Motorsport, Collins Adapters etc)
2. New bellhousing (Mazworx kit)
Option one requires:
- Purchase of adaptor plate
- Gearbox mount + bush
- 350Z prop yoke to make custom length prop (people recommend 2 piece to remove some vibration) as the spline count is 32 on a 350Z whereas this is different to any other Nissan car. (Also think i saw a G35 prop will fit? Not sure)
- Shifter linkage must be modified forwards otherwise it'll foul on the tunnel as it is too far back (Guide here)
- Bellhousing must be machined down the thickness of the plate which in most cases the plate is 10mm, and the difference between SR box and Z33 box with spline stickout is 2.5/2.7mm so therefore a 12.5/12.7mm machining off the front face of the gearbox is required to ensure the spline engages correctly in the spigot bearing
- 350Z release fork must be used, SR release fork is too short and will not engage properly.
- Longer clutch line as the slave cylinder is moved to the other side of the gearbox
Option two requires:
- Purchase kit
- Gearbox supposedly that fits is 2003-2006 350Z
- Split gearbox, do a bit of grinding, cut material off input shaft, remove stock input shaft cover, fit new cast bellhousing (Video Here) (Written guide Here)
- Steel or Aluminium one piece prop (lighter than steel and has torsional dampening properties) or go bare cash dolla for the Carbon version - one piece from gearbox straight back to the diff
- Billet + Machined shifter + linkage mount (OOOOOH shiny)
- Shorten linkage
Either way it's an expensive conversion don't get me wrong.
Doing it with adaptor plate, you're looking at about £1500
The Mazworx kit is getting me at the moment however it'll easily be over £2k inc. box. But hopefully it'll be a one stop fix... and i don't fancy spending £300 every month on a new box - but for the extra £500 over an adaptor plate, it should (fingers crossed) be more substantial and less likely (hopefully) to crap itself...
If anyone has more experience on this and whether they could help, or whether i'm barking up the wrong tree entirely please let me know,
Cheers
~1st 36Mph
~2nd 59Mph
~3rd 84Mph
~4th 108Mph
~5th 137Mph
~6th 172Mph
- Purchase kit
- Shorten linkage
Cheers
