Been an age since I’ve updated this, every time I’ve sat down to do it something has come up so here goes for anyone following
The car came back from millermods with the full bdc spec cage and sunroof delete. What an amazing job Alan’s done adding little bits here and there just to make it slightly different from the rest
Once the car was back in my hands I got the brakes plumbed up into the new copper lines and HEL braided flexy lines. The calipers were also given a good clean and paint. I’ve still to order discs and pads which I’ll do closer to the time it’s going on the road
When the car was away getting the cage down I ordered pretty much everything need to finish the car. The best part being the BN Sports kit
We tried the kit on to try and drive some enthusiasm into the project. While doing this I couldn’t get the rear wheels anywhere near 0 degrees camber with the adjustable bottom arms so we reverted back to the stock arms with fresh bushes and ball joints.
The alloys were just used to get some reference sizes, still to decide what wheels I’m going to go for. Probably going to end up having to run rear over fenders also to give the clearance to run decent sized/spec’d wheels
The kit was taken off to keep it safe while the engine was fitted. The engine was built up with a new water pump timing belt kit including a HKS fine tune belt, cometic inlet and exhaust manifold gaskets, nismo engine and gearbox mounts, “stage 4” paddle clutch. lightened flywheel. New gaskets were used where required and the front and rear crankshaft oil lip seals were also changed.
After getting a shot of an engine crane from my good friend Shand we mananged to get the engine and box fitted abs one piece and mounted up
The radiator and intercooler were then mocked up and brackets made
The exhaust manifold was heatwrapped and the turbo mocked up so check clearance and pipe work
This pretty much brings this up to where we’re at now. Been at pretty much a stand still for the last month while we try to figure out how to marry up the 25 engine loom to the R32 body plugs.
Once the wiring is complete its pretty much the home straight from there; exhaust, custom intercooler pipe work, mapping and paint should see it almost complete
Here’s a couple of photos from a recent drift day in my daily driven R32
If anyone has any knowledge or advice on marrying these looks up it would be greatly appreciated. I’ll try and keep ontop of updating this now I’ve caught up
