custom built high spec pc ideal for gameing
You'll never sell it without some proper detail. what model mother board, what model processor, etc etc
AMD Dual-Core Opteron 175 / 2.2 GHz processor
# Multi-Core Technology: Dual-Core
# 64-bit Computing: Yes
# Compatible Processor Socket: Socket 939
# Processor Qty: 1
# Clock Speed: 2.2 GHz
# Cache Memory: L2 2 MB ( 2 x 1 MB )
# Features: HyperTransport technology, AMD64 technology, integrated memory controller
# Compatible Slots: 1 x processor - Socket 93
graphics card
Radeon™ X1950 PRO - Specifications
* 512 MB GDDR3 memory
* Shader Model 3.0
* DirectX® 9
* Simultaneous HDR + AA
* CrossFire™ readyGeneral
lg flatron wide
LCD display / TFT active matrix
Width 43.5 cm
Depth 22.6 cm
Height 37 cm
Weight 3.6 kg
Enclosure Colour Black ( the image of the product displayed may be of a different colour )
Display
Diagonal Size 19"
Dot Pitch / Pixel Pitch 0.284 mm
Max Resolution 1440 x 900 / 75 Hz
Colour Support Up to 16.2 million colors
Max Sync Rate (V x H) 75 Hz x 83 kHz
Response Time 5 ms
Display Positions Adjustments Tilt
Signal Input DVI-D, VGA
Features sRGB colour management, f-ENGINE technology
Image Brightness 300 cd/m2
Image Contrast Ratio 2000:1
Image Max H-View Angle 160
Image Max V-View Angle 160
Video Input
Analogue video Signal RGB
Digital Video Standard Digital Visual Interface (DVI)
Expansion / Connectivity
Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) 1 x DVI-D - 24 pin digital DVI
* 2 x Dual-link DVI
* HDCP ready*
* Video-in
hope this is a bit more help guys with try and get some pics up in next half hour
jasondrift
No offence but this is not a high spec PC. If you built a PC today, with the lowest spec parts available, you'd still end up with a system which is a higher spec than this. It's alright for the price but you'll not be able to play anything made in the last few years at anything other than the lowest possible resolutions and detail levels.
To be fair to him looking at the pictures, it has got some good quaility components that yeah are a bit outdated hence the price. The PSU is worth a few bob on its own. It high spec compared to the crap you buy at PC World and like.
Quite right though you really do need all the model names for each component to make a good sale thread.
Nice pc for normal use, good luck with the sale.
cheers mate , your quite write about the processor its still 149.99 today on amazon and each 1gb stick of ram is still 69.99 each and i have 2. the harddrives are still 69.99, graphics card is still 109.99 , monitor is still 119.99 hiper ice calling fan is still 74.99 in maplin , sony dual layer rewriters are still 44.99 each in maplin i have 2. cordless keybord and mouse 29.99 in argos.
to build this same pc today new is £784.90 and that doesn't include case and cables, wires etc and motherboard
200.00 is very cheap for this
