Any idea why its called a spool diff?
Im still running a stock nissan LSD. It surprises a lot of people when i tell them. I just drive around it. Its not shimmed and my cars showing 125k on the clock. Works fine.
I wouldnt put a welder anywhere near my car. If it was an out and out track only drift car then maybe, but if i needed an upgrade id be ordering a 1.5 way with a softer lockup both ways./QUOTE]
I'm exactly the same as you mate. Never had a problem with a VLSD. Tried a welder and it was shit so went back to the viscous one. Been fine since and I don't get any of the horrid handling issues but then mine isnt a dedicated drift car. It's used for literally everything.
I used to work on drag cars and it's something already employed among street/strip drivers. You can find switch lock diffs in pneumatic and electric that drop into the rear end housing. They aren't as expensive as you'd think either.I think it would be an expensive idea to develop and when the mojority of people can't/don't want to afford a proper 2 way, it'll bve aimed at a very small market.
Alex B
Not sure how easy they'd be to find that slide into rear end housing for anything JDM. Might have to use the rear end housing from a newer mustang or camaro that way you could keep the IRS but straight axles kill it driftingI used to work on drag cars and it's something already employed among street/strip drivers. You can find switch lock diffs in pneumatic and electric that drop into the rear end housing. They aren't as expensive as you'd think either.
