Driftworks Hubs
Status
Not open for further replies.
Okay here's a picture of the uprights. But don't get to excited. PLEASE MAKE SURE YOU READ THE SENTENCE BELOW:
WE DO NOT HAVE ANY MORE INFO TO OFFER REGARDING PRICE OF DUE DATE. AS SOON AS WE DO, IT WILL BE POSTED HERE :D
im quite curiouse to find out if you will be selling the front wheelbearings and stuff so its a direct replacment?
if not where can i get them from?
oh and i like what you've done with the rears i was tring to work out how for ages :)
good work and keep it up
Do you have any pictures of the rear ones fitted... or just held up against where they go - I dunno why but I can't get my head round what bit is what :wack:
if you look at the one on the right of the picture, the bottom of it is at the top of the picture and that's the inside face you can see. The pokey out silver bit is where the bottom of the rear shock mounts onto.
Does that strange explanation help? :wack:
Nice to see them on the way Phil. Look sexual. Is the tie rod pickup underneath the arm then and all other pickup points moved down?
suppose most of the people tempted to buy this shod already have a pretty well specced s13, that would include 5 stud..... apart from you steve :D xxx
maybe im not thinking this through but of what advantage are the rear uprights? ok the front ones allow loads more lock but what are the rear ones doing? is it just lowering the centre of gravity and ride height?
they mean your car can be obscenely low without fucking up the suspension geometry.... imagine the suspension and arms being where there meant to be, ie stock positions, where there designed to be, but the car being the ride height that most of us prefer :D
So are these going to be available for r33's?
I thought they were
Now I've read back and I'm not so sure
Aahhhhhh
There's no reason you can't use them on an S13 you'll just need to change to 5 stud hubs, since the wheel bearings are larger on S14/15.
I hadn't thought of the stock handbrake but I'm sure they could be modified to work with them.
Not available for the front of R-bodies no, sorry!
Status
