E30 b204 mutt
Fits better than expected cylinder 132 I will get away with because I have two add about 3 inches two each tube for clearance against the block and cylinder 4 will have two be moved about 12mm not two much work involved ordered a saab flange but still waiting for it so untill then i cant weld it up
plate arrived so I can now get the gearbox mated and figure out what I'm going to use for the clutch prop shaft and few other thing sorted you can also use 5 or 6 different bmw boxes with this plate my main purpose for buying it now cant wait to get into it ☹
Flange came for the manifold ended up in a right mess trying to fit it had to butcher the manifold to get everything lined up but got there eventually going to give it to my brother and he will get it tig welded where he works and it will be finished then.
Is it just me or is this turbo silly big
Box is in but not without causing some more trouble after shifting the engine back the gearbox is now to big for the tunnel so I cut it out and will ad a couple of inches two it and weld it back together should be good to go then still sitting at a bit of an angle and will have to shorten the shifter and the angle it will sit at
Thanks for the heads up on that I do already have some tilt on it mabey could put some more but if I level the box the engine ends up at a wicked angle and starts to interfere with other things in the engine bay and it's just to much work to sort all that stuff out when it's like that at this stage now
