ECU master EMU
EMU is way better unit than many more expensive units others on market, but its difficul to use with Auto gearbox. EMU + manual = perfect
What you say ?
I work with EMU and link/vipec, link is still better in everyway, only double the prize.
For the prize being it's for that prize not a bad ECU, but please don't say it's better then most expensive ECU's.
It's better then adaptronics yes, but not as link/vipec, motec, haltech.
Hello, thanks for your answer.
I made this manipulation with vanos. I try to start my engine with VAG coils, 850cc fuel injectors and the fuel is 100 octane gasoline. If it's possible can you send me base map about this set up of car, because all day i try and doing something wrong with setting.
My email is petko_st_petkov@abv.bg
Best regards.
Sorry, i wil not give any maps for free.
What you say ?
Ok, if you buy Motec M800 (4x the price of EMU )it can handle just very simple engine, has nearly no functions. You need to pay for WBO control, Logging option, Varibale cam control, pit speed limiter, launchcontrol, DBW, ALS and many more functions..... This wil costs you nearly again the same price what does M800 cost. EMU = ALL inklusive. And you can still be able to upgrade for better support.
One year back, the EMU was not comparable with Haltech , Motec etc.... but now it can nearly everything like others, what i can remember, it cant just handle the Rotary engine.
And it is very easy to use, has great , great support from manufacturer !
But everybody uses what he likes.
Hello Karel,
Write me, how does it cost complete maps for S54B32 ? And also please write me your telephone for better communication.
Best regards!
Good afternoon, I have a Supra using the 2JZ crank trigger and cam sensors. I use the Napol performance coils and everything is wired in sequential. My fuel system is 2200 CC injectors and I’m using ECU black classic. I’m looking for a good start up map using E85 fuel, if you could help me out please that would be great. My number is 917-436-7888 and my email is sirjum@aol.com. Thank you ! If I have to pay for it I do not mind, thank you again.
