How easy can compacts be made to drift?
jakemk2
I am looking to get into drifting. But having the problem of massively expensive insurance so I am limited to what I can get. I've got my heart set on a BMW Compact. Purely through the expensive insurance I am limited to getting the 318ti.
I was just wondering how easy it would be made to drift and how much work it will likely to be to make one skid.
Cheers,
Jake
It's a RWD BMW, of course it'll drift.
There's loads of them, check the project section.
I know it will drift, and most compacts i've noticed are the 2.5's, so i wasn't sure if the 2.0 would be underpowered.
I was just wondering if it was a good starter car and whether much would need doing. I understand the diff is pretty essential but could standard suspension do for about a month? or will that be pretty difficult without coilovers.
Also is it easy to find a garage that will weld the diff? Just because I don't know anybody with a welder.
- - - Updated - - -
Get the diff welded and get out there.
Presumably it's not an auto?
No definatly not haha, autos don't appeal to me in anyway.
Can't imagine you could drift with one anyway.
e36 318ti is a 1.8 16valve and loves to scream. the 2.0's from bmw are usually gutless, more gutless than a 1.6 sohc. my misses compact slides about in the wet with a 1.6 in it lol
I wouldn't be able to get an e36, they would cost me an extra grand a year than an e46 compact.
The 318ti had a 2.0 and about 145 bhp, I think it would be enough to get the arse out!
I have a very limited choice only being 19 :(
Will drift, use the smallest wheels that fit on with the lowest profile tyres and plenty of psi to keep the wheels spinning faster. :)
1.8ti's rev really quick. As said weld, small tyres lots of air in tyres will teach you more than just having power. Spend £15 on rack spacers and your sorted
Thanks guys,
This was a lot of help! I am going to look at a few next week!
Also as I said in the original post will most garages be able to weld the diff?
Thanks guys,
Most garages will do welding, check out MOT places as they tend to have welding equipment for MOTs anyway.
Go for an E36 318 rather than an E46, might be more on insurance but cheaper parts, cheaper cars and lighter which will make up for it. Interiors of the 36/46 are basically identical anyway
Mine has an M50 2.5 so obviously a bit different to what you'll be in, but Im running stock suspension and lock atm, rack spacers would easily give you enough lock to get you out of trouble to begin with. Stock suspension is ok, but a bit boaty, I'd probably just go coilovers, I got my brand new FK's for £150 from ebay.
A day at Santa Pod will probably help you no end too
A day at Santa Pod will probably help you no end too[/QUOTE
I have managed to find a e36 318ti 16v with very good insurance.
So I maybe on my way in the next few weeks.
And at pod is it just a anyone can turn up thing. I presume you need a ticket.
Should be fine to get you started, I would say get some decent tyres on the front and over inflate the rear like crazy. I had a go in my friends 318 on his first drift day, but what really let it down was not having that grip on the front to throw it in at high speed. Other than that, it seemed fine. :)
