Line Lock
clarkey. climes into his little rubber dingy witha rocket laurcher and goes AE86 hunting
Loving them archs, looks so cool
Save yourself the trouble mate, knowing my luck at the moment the ship will probably get hit by a space ship, driven by Elvis and sink. :wack: :D
More pics in my project thread if your interested. *plug* :smash:
My bro fitted one to his R33, which he drag races. It a small electronic box which is fitted into the brake line, pumps the front brakes solid and lets the rears roll freely. Its activated from a switch on the steering wheel. He uses it to heat up the rears for a decent launch.
In his old R32 he had a manual line lock which needs to be pumped up from inside the car it a bit like a pump. After the burn out he then needed to re pump, manualy the Hicas unit at activate the four wheel drive.
Cant remember the companys name but they are a drag racing service somewhere in Kent(google search it) think it cost fifty-sixty quid form the electronic unit.
High powered cars arnt like ours foogking around with heel and toe aint an option. Seen my bro and his mates spend best part of a month preping his car for three sub 11sec runs, hes looking for more from the R33.
:smokin: Thats why I like drifting spend three minutes preping the car and drive it all month :smokin:
working of shut off valve-
Can shut off valve(of wilwood)be used to lock just one wheel and keep other 3 wheels unlocked with brake pedal placed(considering solid axle at rear and wiring 2 shut off valves together)I need it for an offroad vehicle.Our idea is to use 2 shut off valves and keep rear and one front tyre unlocked while brake pedal pressed so that it can ease steering
wicked stuff, thanks a lot ...
I am just deciding which car i am going to do it to
its just a shut off valve mate as you would find round the house, like ones on water pipes!!
Wicks b&q are cheap!! have some laying around at work i believe!! ;)
