Moskvich 2140 ....got to drift it ! (saab powered page 7)
Re do the bead roller for bigger sheets
and kinda sorted the boot
wow its ready to go ?? good work mate
This is insane!
Nice work mate!
Thanks buds , good to "hear" it :)
So get some free time around hollydays and fill it with work ,not so much as wanted but ....
ahead with engine bay
get the chasis rails ends finished
not happy with rack shaft joint angle , cut rack twisted it back and weld again
more likely :o
not having actual strenght construction under rear doors came out with this
and one off duty shot
Страхотна работа :) Надявам се че след пълната реставрация на купето ще монтираш нещо по-модерно и изискано под капака :) Хубаво е човек да види нещо различно от поредната Е30ка :) Аз съм от варна и имам две 190тки които правя, така че бях приятно изненадан че си използвал мост от 190, поне като за начало :) Пожелавам ти успех и лека работа по колата :)
Благодаря ти , наблизо съм :nod:
So pedals mount , tack them into place and made a bracket
next step seets ;)
feel good :)
This thing is utterly mad! Good on you for the amount of fabrication that's gone into it!
It's going to be pretty strong by the looks of it but kerb weight? :O
Cheers guys !
put on master cylinder without booster , from audi 80 , will count on small bore piston to produce enough pressure , will see , and some bigger front callipers from mercedes 208 with vented disks 280 mm
litle bit sheet work
got a bmw m50b20 gearbox shorter gears compared to siera's one :)
Get rid of steering rack and put an steering box from Opel omega B , whit this front subframe is more practical option for lock
gonna kick it :D
This will be solid as stainless steel bear when you are done!
Any plans with paint?
Think you should grind it off and lacquer over the top ;)
