I'm not being difficult, I'm saying a slide using power, is a power slide. A front drive can never do that. A slide using momentum, whether or not power helps keep it going, is a drift.
I said it was early, you are 100% correct, it is not a powerslide.
the video the OP linked is someone flicking the handbrake 5 x through every corner (McDonalds trays) , show me a video of someone "drifting" a whole lap with FWD and i'll take it seriously.
How would a FWD gain speed through a drift? honestly explain that to us all. As far as i'm know and have experienced, the weight when throttle is applied will shift to the rear, causing it to grip, unless you slam on the handbrake.
you call a "drift" from entry to apex not sustained by power? What happens after the apex and the transition to the next turn?
As I said you have a feel for weight transition and drifting "the right way" in my mind. Get a 318 or an mx5 and you will put people to shame. But physics won't allow you to "drift" in that Honda.
