Now to some more fabrication work...
This is how the engine looked a fair few years ago in the PS13 it came in:
The throttle bodies are from a Gti-R Pulsar and as far as myself and Stu (previous owner) are aware - they are the only set in the UK that are proven to actually work and they came on the car from Japan so trying to get another set to work from images and knowledge from stu from when he took them off or worked with them is proving very difficult considering they are currently in a storage unit somewhere in Essex - i have images of the top, but not the bottom... much head scratching is occuring, mostly regarding the idle control and balancing of the bodies themselves as it is a blow through system with turbo rather than N/A.
For now i have removed the Freddy manifold - only recently when talking to a friend i found out about the reasons freddy manifolds starve cylinder number 4 of air. Apparently there is a video floating around somewhere of a clear topped inlet manifold and it is clearly visible that due to the stroke of the engine it is drawing way more air through cylinder number three than four, so obvious is fact that cylinder number 4's injector is actually injecting fuel and it is seen being sucked back into the chamber and into cylinder number three, making four a lot hotter and meaning the fuel needs to be leaned out on three and richened on four. I'd rather that didn't happen to this engine so have decided to get myself a set of pulsar ITB's.
The reason for this is to hopefully stop the above problems - the only problems that i can see which need adjusting to make fit are of course the hole pattern is to fit a pulsar SR20 so they need re-drilling, the plenum needs rotating through 180 degrees so the inlet is facing the other way (Pulsars have them mounted accross like a FWD instead of long as they are AWD meaning the plenum faces the wrong way) aaaaaand the idle control needs to be mounted remotely... Some holes need capping off, and the fuel rail should fit - with some modification of course.
I got them from P555Ben on the sales section for £90 delivered including an adaptor plate of sorts... which as you'll see so far i have only used for hole location when redrilling the pulsar bodies. When laid on top you can clearly see that along the top row, the holes need slotting upwards and along the bottom they need redrilling completely - i would weld the holes up and redrill all of them properly however i'd rather prove that they actually work first on the car!
Once redrilled and slotted, looking down the bores you can clearly see that they line up perfectly with the head without having to port match or any other modifications which surprised me slightly given the amount of head work it has had done (although also makes sense as any machining would have probably been done inside the port, not on the flange face)
Above the adjuster screws i tapped all of the ports so i can screw in capping bolts to stop anyone coming along and tweaking them... plus it is also so i can mount a throttle cable bracket right near where it needs the most support.
Fuel rail before:
Fuel rail after:
I will be fitting an AN fitting either end so it is a crossflow feed through braided lines to the rear swirlpot setup (y)
And this is how they look at the moment! Tomorrow hopefully i should have use of a bandsaw to cut the ports and rotate round 180 then re-weld. The top half of the plenum also needs modifying to have a 3" pipe on the end which i'll just point directly to the intercooler and then should have pretty sweet pipework.
Had a rethink about the turbo setup while i was there as well so i bought a 44mm Tial wastegate:
This also means i'm selling the holset, cast manifold and ebay external gate as i hopefully should be ordering an AWP manifold with 44mm v band for the wastegate and then another V band on the top port for a v band housing GTX3076r with metal cage and .68 housing... ain't no messin' yo!
Think that's it for now...
Oh, and i found out i'm dyslexic the other day - who knew eh
