BenRice
Well-Known Member
There's a sensor on the clutch pedal as well, but I'm not 100% on if this is fed directly into the ECU. It is possibly sent to the HICAS module
What scenarios does it hit this 5k limiter? Car moving or stationary? Clutch in or out? Can you take a video of this limiter?
You don't have anything to lose by cutting Pin 53 btw. If it doesn't work you can just solder it up or, crimp connectors on.
