Manual boost controller then
plus shipping, plus import taxes, plus rape from the Royal mail.
It'll be £500 or so landed in this country.
I always prefer a cheap manual ball n spring controller personally.
One costs you next to nothing, takes 5mins to fit and set up and does the same thing every time.
One costs a few hundred, can take a while to fit and fucking ages to set up correctly, and usually is a pain in the arse and gives more to go wrong.
I see no advantage of being able to adjust boost levels in-car.
haha where the 'like' button.
yeah but my leccy boost controller has high and low settings. like I have ever used the low...
Why not just pick up a second hand boost controller, the profec B spec 2 go for £150 online.
Another advantage of EBC is you can set gain which will help spool the turbo earlier.
Really, I would of thought EBC is the best at spool up and maintaining that pressure at high revs.
The gizzmo ms-ibcs are a good piece of kit and gizzmos aftercare is second to none. I liked the fact it's a controller and real time gauge all in one. As far as I was concerned, I had to run a vac line through the bulkhead for a gauge if i went with a manual controller anyway, 2 more wires to a solenoid wasn't much more hassle.
Its been a fit and forget item on both vehicles i've run them on. Got one on my modified diesel navara now and it's controlling a heap more boost than you would be on a CA with zero issues.
