RIGHT THEN!!!
yesterday with massive help from Nick and Cas (SXOC Candy Drifter), we swapped mine and nicks sierra subframes over and after calling a mate and asking him to bring my welded diff which i forgot, 35 miles from derby to nuneaton, we managed to fit it
it required a "group A keyway" angle grinding in the end of each driveshaft to let it engage *properly* with the extra weld on the inside of the diff
, thanks to expert grinding from cas, we assembled the subframe, cut another coil off each of the rear springs (total rear lowering of approximately 80mm....) and fitted some 13" drift rims and we were away!!
TIG welding was great and so far is just awesome, it skids the inside wheel and clunks a bit but nothing unnerving since ive not got much grip from a 186/60/13 tyre anyway
it gets understeer if you just turn in, and then plenty of lovely controllabe oversteer if you induce it. my handbrake now WORKS!! and works fantastically too. pedals still a bit spongy so may have to bleed them at some point but they work fine
so thanks a lot nick and cas, youve made me very happy with my car now
and thanks to grant and luke for helpin too
